Results 1 to 10 of 17
Thread: fluids in your driveway
    Default fluids in your driveway
    Light brown or black stains (medium consistency) = engine oil
    Reddish/light brown/black (thinner or thicker consistency) found near center of car = transmission
    Reddish/light brown or Light Green (thin consistency) = power steering
    system (use ATF in BMWs or Pentosin CHF 11 S hydraulic fluid in cars with rear self leveling)
    Clear/Slightly Brown and slick (medium consistency) = brake fluid
    Reddish/light brown/black (thick consistency) found at rear of car = differential fluid
    Yellow/Green/ Pink/ BMW Blue and slimy (thin consistency) = coolant
    Clear shiny liquid (thin consistency) = water (AC drainage)
    Clear/Yellow (thin consistency) smells like urine = pee (probably from your pet, rodent, or teen-ager/friend/neighbor that got drunk the night before)
    If I forgot one...feel free to add or correct.
    Written by: QSilver7
    Hockinson, Washington
    lols at the last one
    Aug 2005
    West Portland, OR
    I was lolling and i found #6.
    EuroLux:. Private Detail
    Honolulu
    Default #7
    white sticky liquid by the passenger side door = last night's hot date spit rather than swallowed.
    pictures?
    Quote Originally Posted by Blitzkrieg Bob
    Sep 2006
    Arizona
    #8: yellowish/clear/reddish fluid found at corners of car--> blinker light fluid.
    Apr 2005
    Canada
    This help to pinpoint a potential trouble on the car, but could you also suggest ways to ged rid of all those stains on alsphalt driveway (to sip oil out of it) ?
    Indiana
    Thats what I thought this was going to be at first. Both are very handy.
    Honolulu
    Default Clean up?
    for concrete
    TSP = trisodium phosphate
    or
    Muratic acid for bad stains
    for asphalt black top = for a fresh spill, put concrete mix (just the powder to soak and bind the oil) periodcally reseal with black pitch. (oils deatroy black top and reduce it to gravel)
    I use cat litter (the clay type) and work it into the spill and sweep it away. Works great.
  1. a e34 will soon return to my driveway
    By winfred in forum 5 Series BMW
    Last Post: 12-08-2008, 01:04 AM
  2. Daily Driveway Droppings -- use what you're given
    Last Post: 06-25-2008, 11:00 AM
  3. New Addition To The Driveway
    By 325ENewbie in forum 3 Series BMW
    Last Post: 02-09-2005, 04:59 PM
  4. I need a larger driveway...
    By Bruno in forum 5 Series BMW
    Last Post: 06-10-2004, 06:22 PM
