Results 1 to 8 of 8
Thread: Give it to me straight Doc!
    May 2006
    NH
    Default Give it to me straight Doc!
    It may have been nothing.Maybe just my mood.I had just screamed at some motorist up ahead riding in two lanes at half the speed limit.They had blown my flow big time and i had had it. Ready to explode when shifting into fifth gear and the gear selector seemed to go into fifth stry easily, like there was nothing there, it usually notches in kind of that got my attention. Then as i began to accelerate...... where are my balls? It was like hardly moving but the mileage meter dove down to nothing this kept my attention. I was accelerating but it just didn't seem to be with regular fifth gear gusto.Maybe i wasn't at speed, i can't recall clearly because i was so infuriated with the goon up ahead delaying my return to my domicile.Then i shifted into sixth and it it seemed to feel no different than fifth... again i may have just been going too slow to be in those gears but i did accelerate.From the next stop first,second,third all seemed normal but fourth seemed a little weak then fifth and sixth also weak but now better acceleration than a few moments ago when my attention was drawn to them... I didn't get much of a chance due to road conditions to open it up and run thru the gears for more than a 1/4 mile but then everything seemed essentially normal, i got up to 100 but something still just didn't feel exactly the same as it had felt.Am I imagining this or does this sound like something comprehensible. I don't think the clutch was slipping in the lower gears but was what i felt "slipping" in fifth and sixth or again was i just not at sufficient speed and there was too much inertia?Thanks.
    1995 540i Manual build 1/95
    Wellington,New Zealand
    do it again...take her out accelerate in a high gear,watch the tacho...
    May 2006
    NH
    yah that reminded me , i did look at it when i first noticed, if i remember correctly, it seemed to be hanging down around 2000-2500 but i was only going about 40 MPH max.That's what i menat by the guy ahead blew my flow. It was a 50 MOH road long and straight and actually goes right past the BMW Indy shop but for no good reason this cretin was doing 30 and i kept expecting him to pick it up but he kept slogging along though i began running thru my gears...... i guess i can take it out in a few minutes. its 10:30 PM here, dark and windy so the highway around the corner should be pretty em[ty... if the tach doesn't move above 2000ish what does that tell you?
    what you are looking for is if the tacho goes up but the speedo doesnt=clutch slipDont make a special trip,just next time you go out
    May 2006
    NH
    Got it , thanks. i think what i noticed was that neither the tach or the speedo was moving as i'm used to and when i felt the shift selector drop into the fifth position with no resistance that was just so unusual i began focusing on it. I think it was just inertia and i was in too high a gear for that speed but in my head i was already doing 70..lol
    Sep 2006
    Leuchars,Scotland
    try booting it in 5th,what ur expecting is a rise in revs without the speed rising,then it'll load up and begin to increase speed,this is how to tell if ur clutch is slipping.sounds like it is to me,either that or u were too low in the rev range to get the usual pull u see, u do say u were in 5th at 30, not many cars wud take off like a rocket at that speed in that gear
    Sig car has gone, but buying an E34 on my return to Britain in 3 months
    May 2006
    NH
    I took it out on the highway a few minutes ago. It seemed OK. Revs were not rising without acceleration. It must just have been a defective posterior steering wheel nut.... I'm thinking my expectation of going faster based on past experience on that road presented a more convincing image of reality in my mind than had my other physical senses .In other words i just got ahead of myself. If I'd been running I'd have tripped over my own feet and ate dirt.Thanks for the helpull reply
    New Jersey
    Take 2 aspirin and downshift.
  1. Temp Gauge Straight Up?
    By JMI in forum 5 Series BMW
    Last Post: 12-21-2007, 06:51 AM
  2. Let me get this straight, lifter noise???
    By 525iE500 in forum 5 Series BMW
    Last Post: 03-29-2007, 01:29 PM
  3. Need a straight head for my '90 M20 eng.
    By COT1 in forum 5 Series BMW
    Last Post: 11-04-2006, 11:02 PM
  4. I have trouble driving straight!
    By NielsGalan in forum 5 Series BMW
    Last Post: 08-24-2006, 07:59 AM
  5. steering wheel not straight
    By chamilun in forum 5 Series BMW
    Last Post: 09-21-2004, 11:00 AM
