Results 1 to 8 of 8
Thread: OBC Totally dead on 95 525iT
    Englewood NJ
    Default OBC Totally dead on 95 525iT
    OK,
    I just spent damn nea an hour searching the archives and no luck.
    My 95 Wagon's OBC Display is dead.. and I checked the fuses under the back seat as well as under the hood, all appear good and test good. I also tried swapping out the OBC head itself.
    Any reset tricks or......?
    Nov 2004
    Winston-Salem, NC
    Quote Originally Posted by Wiseguy
    OK,
    I maybe misunderstanding your post, but have you checked the lightbulbs in the display? I'm not sure what "head" you're talking about. The little black brick is the OBC. If that's what you switched then maybe you've lost power from the plug inthe front consol or something is misaligned.
    Hope that helped.
    -ashley
    Paper Gaskets Suck!
    Englewood NJ
    Ashley,
    The OBC is totally inop. Pushing the BC switch on the end of the stalk does not trigger anything, and I have swapped in a known good OBC. It's not display lighting (The buttons light up at night). I checked the fuses under the rear seat and the fuse on the OBC relay.
    All are good. It's puzzling to say the least..
    Bill
    Bill,
    Did you ever figure out what this issue was? I am having the exact same problem and its making me mental. Thanks!
    Brian
    It's been a while since I fooled with one but as I recall the display lighting is a different bulb than the one for the buttons.
    If you shine a light on it you may see it's working after all.
    Can someone confirm the lighting thing?
    I cant speak for Bill but I know mine is dead. Shining a light into the display yields nothing. I have replaced both the OBC and the bulbs with new ones that I know are working. All of my fuses are working, so I am totally baffled as to whats going on. It doesnt seem like the OBC is getting any power. I'll fool around with the stuff under the bench seat but I wouldnt know what to do.
    Derbyshire, UK
    Wiring diagrams are here: http://shark.armchair.mb.ca/~dave/BMW
    Get out your trusty multimeter and check for power at the OBC connector, then work your way back. There's no magic to solving electrical problems; just a logical process of finding out where the power is and where it isn't.
    1997 535i V8
    La Mirada, CA
    yea im guessing mine is completely dead as when i push in on the turn signal stick for any amount of time, nothing displays in the check control..?
  1. This forum is TOTALLY #*$%#@!!
    Last Post: 06-15-2008, 08:34 PM
  2. Guibo totally trashed (Pic)
    Last Post: 04-21-2007, 06:20 AM
  3. BMW TDC marks totally blow
    Last Post: 07-09-2006, 07:48 PM
  4. Totally shocked at what I found..
    By Barry in forum 5 Series BMW
    Last Post: 02-01-2006, 12:29 PM
  5. Now that my radiator totally lost it...
    By rickm in forum 5 Series BMW
    Last Post: 07-02-2005, 05:19 AM
