Results 1 to 10 of 15
Thread: Making the gearbox less noisy
    Aug 2005
    Default Making the gearbox less noisy
    What oil can I use to make the gearbox less noisy? It isn't whinning, but still, in first and second gears I can hear it from inside.
    1994 520i with M50 engine, manual transmission and air conditioner.
    VIN: GG45422
    Aug 2005
    Mileage is 239000km (guess its about 148000 miles). Currently using Mobil1 ATF Premium 220.
    VIN: GG45422
    Honolulu
    Default Additives?
    To increase the viscosity.
    or
    the old used car dealer trick...sawdust
    Aug 2005
    Don't wanna use any additives. Too scared
    Whats sawdust?
    VIN: GG45422
    Honolulu
    Default that stuff that comes off
    Quote Originally Posted by t_marat
    Whats sawdust?
    the blade of a saw when you cut wood.
    don't use it....it's an old trick used car dealers did to transmissions and rear ends to make them quite
    it doesn't work in engines either.
    Quote Originally Posted by Blitzkrieg Bob
    Aug 2005
    Is there any grade of oil which would make the gearbox quiter?
    VIN: GG45422
    Honolulu
    Default You're running M1 ATF
    Already, so one option would be an ATF additive for older trannies, not a leak stop, but an oil conditoner type additve may help.
    USA
    molybdenum disulfide.
    Nashville, TN
    Redline MTL its a 75w90 - heavier than the ATF.
    Derek A.
    90 535i 5 Speed - Style 5 17"
  1. Noisy valves?
    By dkaarb in forum 5 Series BMW
    Last Post: 09-30-2008, 06:53 PM
  2. Noisy injectors?
    By Black 535i in forum 5 Series BMW
    Last Post: 02-07-2006, 12:20 PM
  3. Are E34's noisy?
    Last Post: 12-31-2005, 05:39 PM
  4. Why is my car noisy?!
    By LMUNick in forum 5 Series BMW
    Last Post: 07-20-2005, 02:17 PM
  5. what is the best fix for noisy doors?
    By billy in slo in forum 5 Series BMW
    Last Post: 05-05-2004, 04:31 PM
