I am going to change the brake and clutch fluid. As far as I know they are the same.
I read in bmwe34.net that the order should be rear right, rear left, front right and front left. However, for the clutch, where is the bleeding screw (or whatever) is located? Anything special I should look out for? Mine is a rh with manual transmission.
I don't have any problems with brakes or clutch. But I think the fluid has not been changed for at least two years.
