Results 1 to 8 of 8
Thread: clicking up front??????
    Default clicking up front??????
    Just bought a 92 535i and on the way home, the right front corner of the car started clicking and the faster the car went the faster the clicking went. After a minute or so, it went away. Now after I drive it to the store, come out 10-15 minutes later, it starts clicking, then goes away after a minute or so. Stop to get gas, starts clicking as I drive away, goes away after a bit. It's very loud! Not a wheel weight. Maybe a wheel bearing?????
    Aug 2005
    West Portland, OR
    valve ticking? I love that sound :-D
    EuroLux:. Private Detail
    Default I don't think so
    The clicking speeds up as the car goes faster, not the RPM's of the motor. I'm in Portland also.
    rock in the tire treads? A wheel bearing usually sounds like a whirring.
    Default No rocks
    It does not do it all the time. Seams to click after it has sat for 10-15 minutes. I can't figure it out!!!!!!!!!!!!!
    New Jersey
    Sticky caliper? Dragging a brakepad causing a chatter, once hot it stops? Cools off,starts again...bearings sometimes moan and groan. (or whir)
    Just guessing...
    Sedro-Woolley, WA USA
    Hmm,,,,new car to you? Wonder what wheels the PO had put on- mean,,if the offset is different than 20 or 25mm,,,and there are no spacers,,,wheels could be rubbing on sometning they shouldnt, then the sound goes away after driving for a couple of minutes.
    USA
    check the brakes.
  1. clicking noise coming from front wheel
    By joshman354 in forum 5 Series BMW
    Last Post: 01-05-2009, 10:29 PM
  2. Clicking from right front of car
    By 1995 525i in forum 5 Series BMW
    Last Post: 01-17-2006, 12:56 PM
  3. clicking noise.....
    Last Post: 01-05-2006, 10:02 AM
  4. Front end clicking
    Last Post: 11-16-2005, 07:13 AM
  5. Clicking during AC
    By ilya in forum 5 Series BMW
    Last Post: 12-31-2004, 11:28 AM
