Originally Posted by
KenB
Managed to get the stomp test work and got 1216 from my first "check engine" light ever. The symptom was sudden loss of power, as if I took my foot off the gas very briefly (a second or two) then it would acccelerate/run normally. The code indicates the throttle potentiometer.
It only happened a couple times and when I restarted the car after stopping, no more CEL or symptoms.
I checked my battery voltage and it is right at 12V, which is a bit low. It is a BMW battery and the indicator is black, meaning recharge. I had to jump the car yesterday after running the CD player and a plug-in vacuum cleaner for a couple of hours, would not turn the starter over. I have run the CD all day before with no problems.
Alternator output is 13V, which seems OK so I think I need a new battery. It's not recharging all the way or holding charge to full capacity. I've done a search and found the info for the Duralast battery, which I will get tomorrow. (anyone know the price difference between a Duralast and a BMW battery from the dealer?)
My question is, would low voltage cause the throttle pot to malfunction and throw the code? Where is the throttle potentiometer?
