http://www.bmwe34.net/ + Bently's + numerous posts in the archives
I've searched and could not find anything informative. Is there a how-to guide to replace the upper control arms? Do I really need a ball joint separator? Can I rent that locally from a rental company? Thanks guys.
Ramon
1994 540iA Nikasil EAT Chip
Tampa Bay, Florida USA
awesome! thank you much.
come back if you have any questions.. i did it a month ago and i can help you out.... 632regal is also someone to talk to
I was able to get mine off with a ball joint pickle fork, 15lb sledge, and air chisel. Took about 30 minutes. Oh and I soaked the piss out of it with Pblaster.
I got one off with a pickle fork, one with a balljoint puller, one with a sawzall, and the last one required a torch and sledge. Make sure you replace them with Lemforder arms and Boge bushings. You can rent an entire balljoint puller kit from Advance Auto Parts. They charge you for the kit and refund it when you bring it back.
The stone age didn't end for a lack of stones. Neither will the hydrocarbon age......
awesome awesome! thanks a bunch guys. I'll let you know next week. BTW, for the common shimmy problem, do I just need to replace the upper control arms, or the lower as well? thanks
pickle fork always works for me.. On the 540i I had more problem taking the bolt off the bushing. Boge bushing? I went with M5 bushings.
95 M-sport SOLDnow NSX
That was the one which required the sawzall.On the 540i I had more problem taking the bolt off the bushing.
I think someone here posted the part number for the Boge M5 bushings. I had planned to go with the M5, but Patrick's brother told me that people who owned M5s were buying the 750 bushings. From reading here, it sounds like there is a significant difference in expected lifetime between the Sach's and Boge bushings, although they are both the same company.Boge bushing? I went with M5 bushings.
Not that I've heard. The M5 bush is toitest.Originally Posted by zhandax
Anthony
03/64 production
