Results 11 to 20 of 27
Thread: HELP! Bought E39 wheels, but they are really close to the car.
    Jul 2005
    New York
    e39 wheels will fit 34 with hubcentiric thingies, they're $4 each from tire rack. 3 seires wheels will fit with big ass spacers. 20mm or so. not the smartest idea, but they will work ok.
    You're my hero.
    Aug 2005
    West Portland, OR
    Quote Originally Posted by angrypancake
    I understand it's not good to have the spacers, but can someone describe exactly why? Just so if I do choose this option I will understand when something is going wrong or not and what exactly is happening.
    EuroLux:. Private Detail
    Aug 2005
    West Portland, OR
    Quote Originally Posted by CharlesAFerg
    Seriously I actually need to know what i need to put on the car to make them fit, or exactly why it's not good to have wheels like this on the car.
    Thanks!
    Honolulu
    Default You'll need spacers
    big ass spacers....
    They are made and can be bought....but beware.
    unless you only drive parade routes on Sunday or have a schedule for wheel inspection, I'd avoid big ass spacers...one more thing to fix.
    Aug 2005
    West Portland, OR
    lol goddamnit...
    I'm just gonna ask someone else.
    Nobody says why, just that it's BAD.
    why will my wheels fall off after a certain amount of time, not long enough studs??
    Houston, Tx
    Those should fit. It's basically a 16 inch version of the basketweave updated. The offset looks the same too.
    "Scarlet" `97 540/6 with sleepy mods.
    "Box Car" '87 535isA - Old School Charm, new school Flair
    Dec 2005
    Independence Oregon USA - pop. 6000
    You will need longer studs for $ure - if the original studs reach through the spacers to the rotor hats at all they will only be holding by a thread or two - you're just gonna hate that moment when you see your wheel(s) pass you before the car drops. BTDT. Course it will probably come loose under stress - ever try cornering on a rotor? By adding spacers and centering rings you are increasing the # of places your wheels can be off center and misaligned: major potential for wheel wobble. Dats why.
    Tom
    lol goddamnit...
    Kingston, Ontario, Canada
    lol goddamnit...
    Chalres, from an engineering standpoint, the spaces provide two interfaces for tolerances to go wrong, instead of the regular one interface.
    BMW wheels are all "hub-centric", meaning the wheel's axial centering (i.e. in-line with the axel's extended centerline) is maintained through contact between a raised radius on the hub, and a matching machined surface on the inner mounting surface of the wheel. The bolts simply hold the wheel to the hub, they provide no centering effect (unlike non-hubcentric wheels where the bolts or nuts actually maintain positioning and alignment of the wheel to the hub.)
    On a standard (proper) offset wheel (E34, E39 (with hubcentric rings to "shim" between the smaller radius of the hub and the larger radius of the relief machined in the mounting surface of the wheel proper, thus maintaining proper axial alignment), E32, etc...) there is only alignment-critical contact between hub and wheel. With spacers (which also have to have hubcentric-machining BTW) there is contact from hub to spacer, then between spacer and wheel. There is always some tolerance for play, but in this case, you've doubled the potential mis-alignment, and that is more likely to cause overall alignment problems and unwanted vibrations.
    Cheers,
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    Philly, PA
    I've also heard that longer lug bolts and spacers put more stress on your wheel bearings leading to shorter replacement intervals.
  10. #20
    Aug 2005
    West Portland, OR
    Quote Originally Posted by Alan_525i
    Thanks guys! They're going on craigslist tomorrow lol
  1. Replies: 7
    Last Post: 10-06-2004, 12:18 PM
  2. Had a close one today. :P
    By rickm in forum 5 Series BMW
    Last Post: 09-03-2004, 09:53 AM
  3. Is anyone close to these cars?
    By Sweetwater in forum 5 Series BMW
    Last Post: 07-29-2004, 08:48 PM
  4. How close do you sit to your BMW at work?
    Last Post: 04-01-2004, 02:53 PM
