ahhhh...no need to remove the struts, no need to remove the sway bar links either. Thats what I thought when it took hours and hours. I dont even go under the car now, all done through the wheel well.
Originally Posted by
stu1
As Jeff says, searching is good and will work.
Having said that replacing the thrust arms is a moderately difficult job (I went through two separators doing mine and the third was bending before I got the blow torch out) - especially if they haven't been done before and everything's all shitty and rusted.
You will need to remove the struts and will need a decent torque wrench, 16mm spanner (for the swaybar links), 24, 22, 19mm spanners and sockets and then you have to get the old bushes out and the new in (hint: take them to a shop with a press
Good luck!
Stu.
