Results 1 to 10 of 13
Thread: "Clacking" noise just after start-up
    Fort Worth, Tx
    Default "Clacking" noise just after start-up
    Hey all,
    First of all, thanks to everyone for giving me something to read at work instead of doing....work. haha
    My problem isn't really serious, it just makes me worried. After I start the engine (no weird noises there) it settles down to idle and then starts "clacking" for lack of a better word. Now I know this is a new noise because my car has always had the signature valve ticking noise, but this is new and different. It also doesn't follow a certain pattern i.e. clack-clack-clack-PAUSE-clack-PAUSE etc. It does this almost every time I start it after it has been sitting for more than say, 10 minutes. It also doesn't seem to matter what temp the engine is at upon start-up. Finally the engine also seems to run more rough when this happens, but the idle (according to the tach)is rock steady. The clacking will go away as soon as I start driving, and return the next time I start it.
    Any ideas on what this might be?
    Thanks in advance.
    Mar 2004
    NSW, Australia
    Is yours manual or auto?
    Fort Worth, Tx
    Sorry I guess that isnt in my banner, its manual.
    Dunlap Illinois
    When's the last time you adjusted the valves?
    Sep 2006
    sweden
    maybe the belt is getting worn out or the tensioner
    I dont know if there is one on this car but i had a car do the same thing and it turned out to be the belt tensioner was going
    Sep 2006
    sweden
    or was it the alternator clutch or something like that...
    Jan 2005
    Scotland
    Possibly some accessory on the way out? Power steering pump, water pump etc.
    Fort Worth, Tx
    Thanks for your responses guys. If it was a belt or an accessory going out would it stop making the noise after driving? I'm not sure when the last time the valves were adjusted, but I do know the HG was changed 15k mi ago and the PO claimed the valves were adjusted then, so its probably time to do it again....right? The other thing I was thinking is maybe the clacking is caused from lack of oil? Like maybe upon start-up not enough oil is getting to the head, isn't there some issue with the banjo bolts?
    Thanks in advance.
    USA
    .....timing chain?
    .....oil pump chain?
    Mar 2004
    NSW, Australia
    Possibly your dual mass flywheel. It's a common thing.
  1. strange noise "ddrrrrr" from 3100 to 3300 revs
    By paschalisg in forum 5 Series BMW
    Last Post: 10-31-2007, 03:25 AM
  2. Remote Start Alarm System that bypasses "CODE"
    By saj3n in forum 5 Series BMW
    Last Post: 10-26-2006, 04:49 PM
  3. cruise control actuator making "noise" before car starts....
    Last Post: 11-05-2004, 09:36 AM
  4. out of round tires and eliminating "thumping" noise
    Last Post: 07-03-2004, 10:06 PM
