Results 1 to 10 of 16
Thread: No BRAKES!!!
    Greensboro, NC
    Default No BRAKES!!!
    Toady I just recieved my new clear/red depo lights off of ebay. Sorta like these:
    http://cgi.ebay.com/ebaymotors/BMW-E...35844199QQrdZ1
    Okay I took out my old lights, replaced them, everything works fine, but then brake light circuit comes on when i depressed the pedal. This is funny b/c they never engaged with my other (old) lights. So i was kinda doubting it would be the brake light switch. I HAVE NO BRAKES AT ALL!! What else could it be? I checked the fuses under the hood, but they were all fine. What next?
    Greensboro, NC
    maybe it is the switch, seeing that all the lights are out at once. How can you tell if a switch is gone bad, and can you fix it without replacing? I can buy a new switch,but i just dont want to take the chance of getting pulled ova' b/c of not having brake lights.
    Greensboro, NC
    anybody, im in a jam here.
    Nov 2004
    Gateshead,UK
    So your brake lights worked before you fitted the new tail lights? Did you have to replace the grey plastic bulb-holder unit? Get hold of a multimeter and check that the 'brake' wires are going +ve when the pedal is pushed.
    HTH,
    Shaun
    Greensboro, NC
    no, i used the old bulb holder. Okay, ill try and check that too.
    Greensboro, NC
    okay i brought a brake light switch from the dealer. Unscrewed the black plastic panel above the brakes had to unsrew the panel under the steering wheel as well. I get a flashlight, but i dont see anything that resembles the switch. Where actually is it located? I see the alarm noise thing, a couple of connectors, but i dont see the switch. Is it located behind something or in a hidden place?
    Greensboro, NC
    is the switch under the steering column or is it down by the pedals? I opened the panel by the brakes not under the steering column. Was i in the right place?
    Greensboro, NC
    all im asking is where is the brake light switch located at; right under the steering wheel or way down below by the pedals. I know somebody knows. Sheesh! just need to know what it looks like so i can replace it. already got the switch. plz give me some help!
    Frisco, TX
    on my e36 it was down by the pedal. not sure on the e34.
    Greensboro, NC
    okay i guess im looking in the right place then. Just have to look harder i guess
  1. Which big brakes for an e28?
    Last Post: 08-08-2007, 11:15 AM
  2. Replies: 10
    Last Post: 02-16-2007, 12:34 PM
  3. Brakes
    By Jehu in forum 5 Series BMW
    Last Post: 10-28-2006, 11:28 PM
  4. m5 brakes
    By skr in forum 5 Series BMW
    Last Post: 12-03-2005, 08:57 PM
  5. Value of 4-pot e31 brakes
    Last Post: 07-16-2005, 07:03 AM
