Grind one up, make sure it is a rock. If coolant is left in the car too long weird things can happen as it breaks down and reacts with the components it is running through. Id be pressure flushing the block, the heater core, radiator and all the pipes.Originally Posted by Michael999
What kind of coolant was it running? Sounds pretty bad bro, but at least you have caught it now not later...
Is the auxilary pump still working?
Be careful rebuilding the heater valves, the valve stems are very brittle and are easy to break. It is a non-servicable item.
