OK, I bought this euro E34 M5 instrument cluster to install in my Touring. Before I start tearing it apart has anyone converted one from KPH to MPH? All I want to change is the speedometer. The tach is fine as is, I'll use my coding plug from the Touring cluster so it reflects the correct mileage, don't care if the auto trans display doesn't work, doesn't matter about the tank gauge being a little different or the oil temp gauge that probably won't work. All I want is the speedometer issue addressed. I'm assuming that just swapping the speedometer dial won't get the job done because it'll probably read incorrectly so I guess swapping the entire speedometer assembly is the way to go if that can be done. If it can't I really don't have a problem with KPH because I lived in Germany 10 years and I'm used to it. Just rather have the MPH. Just looking for some info before this stuff is laying all over my kitchen table.![]()
Thanks.
Paul
