Results 1 to 7 of 7
Thread: Alternator replacement 80amp or 115amp
    Jun 2006
    Shenandoah Pa
    Default Alternator replacement 80amp or 115amp
    I am considering replacing my alternator.. If I dont drive for a couple of days it wont start. I put it on the machine and everything checks out diodes are ok.. It just takes a dive when I start to pile on the accessories.. The battery is new as well. So what I really need to know is if it matters whih one I use and if it is actually better if I use the 115amp
    Thanks
    jim
    Could the battery not be holding a charge? Assuming it starts and drives fine under daily use (without leaving it sit for a couple of days), I might wager that it isn't holding the charge. Battery < Alternator.
    Bill R. might help.
    Dave M
    tempe
    maybe there is a voltage drop possibby a bad ground or something.
    Sep 2006
    Overpelt Belgium
    It depend on what is on your car.If you have lots of elektronical stuff in it i woult choose for a bigger altenator.
    Horse Country
    You don't just "switch" to a higher rated amp alternator. They are supposed to be used for cars with specified requirements i.e. stereo amp, more accessories, etc.----Sometimes when the brushes wear down, they flop around a bit and f**k up the charge. How is your brush pack?
    Hockinson, Washington
    I had the exact same problem. I had a current drain, and the battery was bad from being dicharged by the current drain.
    PA
    When my valeo alt failed I went to a bosch alternator @ 140amps. Very nice. You have to get a new pulley though - the Valeo and bosch units have different pullies and no the pullie does not come with the alternator.
  1. E34 540 Alternator replacement
    By choccibicci in forum 5 Series BMW
    Last Post: 12-23-2006, 01:31 AM
  2. E32 750 alternator replacement
    Last Post: 07-13-2006, 07:05 AM
  3. M60 Alternator Replacement
    By MantecaBMW in forum 5 Series BMW
    Last Post: 01-12-2005, 05:56 PM
  4. Alternator replacement???
    By Thurgood in forum 5 Series BMW
    Last Post: 02-15-2004, 11:23 PM
