Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Need help removing an oxygen sensor.
    Sep 2006
    Erie, PA
    Default Need help removing an oxygen sensor.
    Hi
    I have my new oxygen sensor ready to go but I can't for the life of me get a good enough grip on the old one to remove it. I have a bently book but that doesnt give much info. I brought an adapter for my socket wrench from autozone but the clearance above the sensor isn't enough to fit the adapter on and remove it (this is the part on the exhaust system, not the pull-out part closer to the engine). Does anyone have any suggestions on how this can be removed easily?
    An update for anyone who remembers, I finally fixed the oil leak on my car...it turns out sealant was necessary on my valve cover head.
    Nathan
    Black 1995 525i 100K Mi
    Nat1
    chop the top of the old sensor, you dont need it anyways. then pop in the new unit.
    Honolulu
    Default Do you have a box wrench?
    If not you may have to un do a few hangers to lower the exhaust for more access.
    Wichita KS
    Ditto. On my car I have to unhook the exhaust hangars and lower the pipe to reach the O2 sensor.
    Sep 2006
    Erie, PA
    Thanks for the replies...how do I go about undoing the exhaust hangers?
    Nat1
    Sep 2006
    Erie, PA
    Quote Originally Posted by Blitzkrieg Bob
    Hi, I dont have a box wrench..just a regular ratchet wench...unless that's what a box wrench is
    Nat1
    Honolulu
    Default buy more tools
    this is a combo open end and box
    Aug 2005
    Iowa, USA
    I have done the procedure on my cat which is like yours, what helped me out was to remove the heatshield that is above the exhaust, protecting the driveshaft et al. It has 4 or 6 bolts that hold it up, once you remove those wiggle the shield towards the rear of the car, the added volume should help you in reaching the sensor and manouvering your tools
    let me know how you fare.
    1995 525i "Stefanie"
    Sep 2006
    Erie, PA
    Wow, that's the best looking wrench i've ever seen!!
    I have one of those, a 1/2" that is that right size...there just isnt enough clearance to fit it
    Nat1
    Sep 2006
    Erie, PA
    Thanks much, I'll try that
    Nat1
  1. removing a rounded off oxygen sensor
    Last Post: 08-26-2009, 09:24 AM
  2. $775 Oxygen sensor in NC
    Last Post: 11-01-2007, 07:04 AM
  3. which Oxygen sensor is #2 ??
    By lvngdead in forum 5 Series BMW
    Last Post: 06-10-2006, 01:46 AM
  4. No oxygen sensor !!!
    By Ali in forum 5 Series BMW
    Last Post: 04-23-2005, 02:54 AM
  5. Oxygen Sensor
    By jbw535i in forum 5 Series BMW
    Last Post: 03-24-2004, 11:38 PM
