Results 1 to 5 of 5
Thread: Body Rot
    May 2006
    NH
    Default Body Rot
    A couple of weeks ago i found what I'd call serious rot.Under the door sill, is that the rocker panel? On each side there are what i assume are drain plugs. The plug is missing from the passenger side and the surrounding metal is badly corroded since there is carpet immediately above the opening so when i drive in the rain and the carpet absorbs water it feeds rusting.I don't know if i need to have body shop refit that whole section or if i can get away with wire brushing away the rusted metal, applying a rust inhibitor then maybe JB welding a piece of sheet metal over the opening and blasting the whole area with spray on rubber sealant. What would you do?
    1995 540i Manual build 1/95
    Jun 2005
    I would try your plan before going the body shop route.
    New Jersey
    I agree, the DIY route on an area that is not plainly visible and doesn't need finished paintwork soumds like a good plan.
    Would probably save a hella lotta $$$ over taking it to body shop.
    Nashville, TN
    I have a similar issue with the lower panel in front of the front dooor from a car which came from Boston. Can I shoot Naval Jelly (or phosphoric acid) in the void to stop this beast from taking hold? What is recommended?
    The stone age didn't end for a lack of stones. Neither will the hydrocarbon age......
    May 2006
    NH
    Some of ya'll may want to take a gander under your body to make sure these plugs are still seated properly and you aren't cancer ridden like this...
  1. M5 Body Kit
    By Sam-Son in forum 5 Series BMW
    Last Post: 09-10-2007, 10:06 PM
  2. body kit
    By Dr. evil in forum 5 Series BMW
    Last Post: 08-23-2007, 12:35 PM
  3. New Body kit
    By blackpawn5 in forum 5 Series BMW
    Last Post: 07-20-2006, 01:15 AM
  4. Body kit?
    By angrypancake in forum 5 Series BMW
    Last Post: 09-23-2005, 01:40 PM
  5. My new body kit
    By brodee in forum 5 Series BMW
    Last Post: 09-16-2005, 12:10 PM
