My driver's side window stays up, refuses to come down. When pushing the switch button at either up or down direction I can hear just one click sound on the power window motor, but the windown does not move at all.
I already removed the door panel and carefully checked the regulator and motor. I think the motor is the culprit since it does not crank. I am going to replace it as soon as possible. I searched and read old threads about replacing the motor. Also, looked at the Bentlry. All said that, first I have to drill out rivets to remove the regulator, then unbolt the window motor from the regulator. Well, I am kind of sacry to drill holes on my car. Is this the no way out?
Since the window is staying up now, will the windown drop down immediately as I remove the regulator? How to prevent any accidents?
Jerry
