maybe some help
Originally Posted by
Dash01
Thanks, I had that much done. But, having a senior moment at the end of a long day with lower back pain, I can't remember what the larger vac. tube goes to. It's thicker than the other two lines off the niples, takes a sharp turn, and is ~6-8" long, based on the one I took off.
And, there are two thin elec. wires that go from the injector harness to the starter solenoid, attaching to the small nut at the top. I think that's how they were. Any ideas on that?
For the tubing-
I tried to buy a replacement, but the stealer didn't have one- I think it's 6mm (?) hose and I just used some new fuel line hose (6mm) and routed it so that the curve would not kink- it goes to the breather valve mounted to the intake manifold bracket
one of these (the smaller) is attached on the lower side of the starter- I think this was an 8mm nut
the other should attach to the top side and should be a 10mm nut.
They should not be interchangable due to the hole diameters on the electrical crimped terminals- (the larger hole will fit over the smaller terminal on starter, but not the smaller over the larger)
sounds like you're close and almost finished-
good luck
Chip
'92 535i 5sp
EAT chip, Sachs kit, RRT sport control and upper thrust arms, SS brakelines, Camber plates, Subframe inserts, 3.64 Diff, M5 (3.6L) calipers.
'87 325iS
