Results 1 to 9 of 9
Thread: pics / inspection of pitman arms?
    Sep 2006
    Default pics / inspection of pitman arms?
    I just got a nice 91 525i last week. It has rear-end wander on sweepers, which I attribute to either subframe bushings or pitman arms. I've never had an e34 before, so any help would be appriciated.
    Can anyone tell from these pics whether the pitmans look bad? They look a little 'off center'. The rubber lip easily moves when I push it.
    The car doesn't make any 'clunk' sounds ever, in fact, its stone quiet, so I don't think the subframe bushings are shot.
    Thanks for the help.
    Honolulu
    Default They look okay
    when they fail, the rubber boot blows out, the grease is gone and all you're left with is a dogbone with a couple of metal bushings flopping in them.
    Hockinson, Washington
    Quote Originally Posted by Blitzkrieg Bob
    I hate to say youre wrong, but in this case you are. I had them fail and the boots were perfect. After removing them they were extremely sloppy and loose.
    Honolulu
    Default this shows what I experianced
    http://www.bimmerboard.com/forums/posts/51281
    Mine were far worse than this guys, clearly I needed new ones.
    I was just saying that they definetely can be worn out even if the boots are intact.
    Sep 2006
    thanks for the input guys, for sure. I think given the ease / price I'll change them asap. I'm done my timing belt on my e30 so the garage should be free barring any problems starting it up tomorrow.
    Here's a pic of the beast in question, for kicks.
    dont get then crap ones off ebay namely FCPscrotum I went that route as a test and anything they sell is crap and needs replacing after a month.
    Honolulu
    Default Mine are hamburg tech crap
    One year and still holoding on.....
    But these are easy to replace, so it's not as bad as a front end of FCP Hamburg stuff I guess.
    the rears have already failed, theres more slop than the originals I took out, was nice for a week or so. go check them puppies Bob.
  1. Pitman Arms too?
    By Jehu in forum 5 Series BMW
    Last Post: 02-03-2008, 12:00 AM
  2. Rear Pitman arms, What do they do?
    Last Post: 08-23-2007, 04:50 AM
  3. Rear pitman arms (dogbones) failure
    By zmuff in forum 5 Series BMW
    Last Post: 06-27-2007, 07:46 PM
  4. Where to get Lemforder Pitman arms
    By Jjcarr in forum 5 Series BMW
    Last Post: 05-30-2006, 07:26 AM
  5. Replies: 21
    Last Post: 09-08-2005, 08:57 AM
