Results 1 to 10 of 17
Thread: Erratic engine behavior
    Sep 2006
    Newnan
    Default Erratic engine behavior
    I purchased a 1995 BMW 530ia with 99000miles at a prive import dealer. The car started, idled and drove exceptional. With that in mind and two test drives i wasnt worried about the Nikasil problem.
    Anyways, 2 months later and my idle is completely f*d. Ive searched and read over a hundred threads on this forum and there seems to be so many different things that can cause a rough idle, i cleaned out the MAF, got new bosch spark plugs and tomorrow im gonna clean the idle control valve. Other than that i dont want to spend alot of money doing a checklist repair. Here is exactly what happens everyday now.
    I start my car around 6am every morning, it sounds like its barely alive, sometimes stalling until i give it gas keeping it at 1000 rpm. it'l make a chugging noise for the first 3-5 miles traveled durring idle. after i drive it a little it acts completely normal until i stop for more than a minute. Then the rpms will drop randomly to around 400rpm and stay like that until it stalls or until i drive again(whichever comes first)
    I noticed out of anger when i accelerate hard in sport mode the problem magicly goes away and the check engine light/rpm drop happens less than half the time if i kept it in economy mode. im tired of having it stall while im stopped on a busy highway and i need to fix this asap. Unless you guys know what this is; here are the steps im going to go through with
    1. clean ICV
    2. New 02 sensors
    3. Check all sensors that may be possible culprit
    4. Check All vacum lines as best as i can
    5. New fuel pump
    6. New valve cover gaskets
    7. chip it(heard it helped some people)
    there is one other thing. i have leaky valve cover gaskets that has let a small amount of oil around the spark plug coils. Maybe my coils are shorting out? what would be the effect of a shorted out coil.(noise of the engine, rpms, etc?)
    thank you to everyone that helps, i love this car and i really want to keep it alive.
    Jan 2005
    Scotland
    I think I'd be inclined to make sure the mechanicals are good first with a compression test and mebbs a leak-down test. If that's Ok, then things aren't too bad
    Albany, NY
    Read through this entire thread:
    http://www.bimmer.info/forum/showthread.php?t=15686
    and here:
    http://www.bimmer.info/forum/showthread.php?t=17421
    My M60 is doing the same thing, guess it is pretty common this time of year. I ordered all my gaskets and they'll be going in next weekend.
    Sep 2006
    Newnan
    damn... looks like im gonna be busy next weekend. Figure il do the pcv plate, intake gaskets and valve cover gaskets all in one weekend.
    thanks for pullin that up for me. guess it was the only one i didnt read...
    Im gonna see what happens when i clean the ICV and put in the o2 sensors tomorrow. If saturday morning its the same it looks like im gonna have to fork out the money ive been saving for the M parallel staggered set... Damn it...
    Sep 2006
    Newnan
    well there was a ton of crap in the icv. i almost clicked my heels when i saw it. only to be thrown back to my checklist. Cleaning the ICV didnt help the idle... Only seemed to help it from stalling, since i didnt stall today. Looks like o2 sensors tomorrow.
    Sep 2006
    Newnan
    well i got new o2 sensors, not one bit of change. Im gonna tackle the new intake manifold gaskets and valve cover gaskets begining of next week. Do you guys think that leaky valve cover gaskets could be the only reason for this? i dont want to spend two days on this and it still act the same.
    by the way, anyone got any pics of their painted valve covers? im thinkin about painting mine silver while theyre off.
    USA
    check to see if the coils are at the right ohmage, and pull the spark plugs and check their condition. a rapidly deteriorating condition like yours is usually do to bad fuel, what kind are you putting in your car?
    get a fillup from 1/8th tank with 92-93 octane ETHANOL FREE gas, drive for about 20 mins, then open the e-box and yank the ECU harness plug off and the trans computer harness off.
    then let the car sit like that for a day while you charge the battery using a trickle charger such as the bmw one.
    my car runs like total crap if there is any ethanol in the gas or if the batt voltage is a bit low.
    also check to see if there is oil in your coolant...
    there is also the crank ventilation thing at the back of the engine that can make the car run EXACTLY like you are describing, but do the gas thing first to narrow it down.
    i have one sitting in my garage waiting to go into my car when mine starts running bad. its about $70 for the kit at bavauto.com
    USA
    oh and i am painting my valve covers too
    i just dont have much time, so it will probably be a year before its done :/
    Sep 2006
    Newnan
    Default hmmm
    il try that tomorrow. although ive put nothing but 93 octane in the car since i got it. ive been fillin it up with quicktrip gas and flash foods(american) gas. and i thought it sounded like a fuel problem too. so now im just gonna fill on exxon and BP. i swear its gotta be a sensor problem because it will drive perfect and then i stop it makes a "click" noise and it stall or idles like its on its dying minute.
    i know i have a valve cover leak so whatever might as well fix that too.
    it just seem like things are getting worse. since im sick of listening too it idle like death when i first start it i just give it some gas, back out and head down the road. problem is that its idling so bad that my power brakes/power steering dosent want to work so well = accident, untill it warms up.
    USA
    click or pop?
    if its popping its usually vacuum pulling oil through the plug threads with air.
    clicking may be a coil shorting.
  1. weird fix for erratic idle, backfiring engine
    By dreamaker in forum 5 Series BMW
    Last Post: 10-06-2006, 06:52 PM
  2. Replies: 5
    Last Post: 03-20-2006, 01:52 PM
  3. weird engine behavior
    By grave77 in forum 5 Series BMW
    Last Post: 08-06-2005, 03:43 PM
  4. Erratic fuel guage behavior at 1/4 tankfull.
    By pundit in forum 5 Series BMW
    Last Post: 01-06-2005, 07:49 PM
  5. Erratic alarm behavior
    By andyman32 in forum 5 Series BMW
    Last Post: 05-10-2004, 08:16 AM
