any help?
i hit some road garbage and i broke my lower passenger front trim. anyone know how to fix this? thanks in advance.
any help?
....you should check out Bruno's site (link below) on how to remove/replace them:
http://www.bmwe34.net/e34main/mainte...door_trims.htm
If this is not what you were referring to, one possible reason why no one has responded to your post might be that your description was a bit too vague.
Hope this helps,
Tim
'91 535iM
Originally Posted by ronn227
I wouldn't say it's vague. He has a picture of exactly what he's talking about.
Unfortunately, I can't help you ronn. I'm just here to make useless comments today I guess. Good luck.
If you ever discover that what you're seeing is a play within a play, just slow down, take a deep breath, and hold on for the ride of your life.
-Deep Thoughts by Jack Handey
...but I can see it now. I'm not sure how I'd go about fixing that either. Yikes.
Sorry I wasn't able to help either.
Rgds,
Tim G.
Originally Posted by garretb
haha, thanks anyway guys. i appreciate you taking the time to respond to my post.
i think i'll just go to home depot and buy some adhesive for plastic.
What you want is to remove the bumper (this piece is attached to it) and repair from the inside with a quality fiberglassing job. I used to build homebuilt airplanes and I used the same techniques to do this repair. It came out really good too. If you know someone who can do this the repair can be made for about $20 worth of materials.
If you like, I can tell you how to do it but I reccommend you do a few practice layups before you work on your car. It's not too hard to make it indecernable from new, but it does take a little technique. How "handy" are you?
Mark Hall
'95 525iA EAT chipped (just one now )
'98 528iA
