Results 1 to 10 of 12
Thread: E38 shifter handle installation DIY
    Default E38 shifter handle installation DIY
    I got some pics and info from Germany
    http://www.bimmerboard.com/forums/posts/257144
    http://www.bimmerboard.com/forums/posts/256767
    The E38 handle has no lock bolt in front of the handle, it is screwed in. But you cannot just glue on the handle to the lever, because sometimes you have to remove the handle to get the wood out in the console, for example to clean the gear selector switch.
    So you either have to buy the metal rod from the E38 also, or modify the E32 rod by inserting a bolt where you can then screw in the handle. And the white plastic pin has to be adjusted too.
    Above shows some solutions.
    Aug 2006
    Sacramento, CA
    Thats awesome! Would this work on an E34 as well?
    95 540iA: Euro Clears & More Mods to Come Soon!
    Sacramento, CA USA
    Should work, if it works on E32.
    Some mods rquired as shown, but that is not too complicated.
    Aug 2006
    Sacramento, CA
    Sweet! I am going to look into this!
    Sacramento, CA USA
    Feb 2005
    Nowra NSW Australia
    I have just done this, but bought new gear shift leg from BMA if I had seen your pics I could have saved A$45. and been less apprehensive about cutting 10mm or so off the shifter. all in all I was happy with the mod " my oem timber T handle was very ordinary.
    Quote Originally Posted by Fred Tyler
    Pics Fred! show us the pics!
    This is a great upgrade
    E30 318iS & BMW K1200LT
    Quote Originally Posted by GJPinAU
    Yes that'd be great. I still don't get how the e38 knob is secured.... the e34 one has a torx screw that threads into the post. Is there some kind of clip on the 38 one or is it an interference fit?
    I have an e46 handle on mine, it is great but I stopped short of cutting the shifter post for the moment. It is too high, but I wanted to sort out a way to fasten it first. However it is a tight fit, so the 46 handle is working okay so far and I could cut if down whenever I feel like it. I like the modern shifter surround too. e46 may be a possible option here too. Nick
    How about drilling a small 2.5 mm hole in front of the knob and a small thread into the metal of the lever, same like your present handle of the E34 is secured? Or replace the lever against one from the E38.
    Feb 2005
    Nowra NSW Australia
    The e46 knob just pushes on to lock, you may read, where some folks have hit themselves in the head while trying to get them off. They is a little twist movement between the knob and stick, but I don't see the need for the original grub screw.
    Is yours a shorter/diff stem or cut down? Mine is way too tall but refuses to 'lock on' It won't go down any further... are you saying I should try to twist it whilst pushing down?
  1. Automatic shifter handle problem
    By Garlic Breath in forum 5 Series BMW
    Last Post: 03-16-2009, 10:12 AM
  2. outer door handle gasket installation instructions
    Last Post: 08-19-2008, 10:40 AM
  3. automatic shifter handle
    By tnt525i in forum 5 Series BMW
    Last Post: 11-19-2005, 05:24 AM
  4. Tee Bar Handle
    By stx133 in forum 5 Series BMW
    Last Post: 10-07-2005, 08:01 AM
