Results 1 to 10 of 10
Thread: hid's oem harness or battery supply?
    NW UK
    Default hid's oem harness or battery supply?
    hi all,
    thinking of some hid's but noticed soem kits advertised with or without relay harness' fed from battery
    to those of you with hids installed, did you guys just feed of the original harness or fit one of these battery/relay harnes looms?
    regards
    sam
    http://cgi.ebay.co.uk/XENON-LIGHT-HI...QQcmdZViewItem
    http://cgi.ebay.co.uk/HID-XENON-CONV...QQcmdZViewItem
    T·O·R·O·N·T·O
    OEM wiring harness, but check your connectors wiring to ensure that the wire isn't brittle or fraying. Any resistance going over aged wiring may cause problems (fire?) for you. Other than that, OEM harness and an upped fuse. That's it.
    OEM and change fuses to 15A... No problem for 5 years now.
    NW UK
    she's a late 1990
    the wirings obviously old now but the loom to the headlights looks in good condition
    thanks
    sam
    NW UK
    Default warm up time?
    i meant to ask
    how long does it take for them to warm up?
    thanks
    sam
    It takes about 10 seconds to get good light... It will be full brightness at about 40 seconds. I never timed it. Normal HID warmup. It doesn't matter how old because the current draw of normal bulb is 4A at the most... which is well under the rating of the existing wire.
    HID may suck up 14A for brief period and then finally settle on about 3 amp draw... something like that... lower than regular bulb.
    NW UK
    cool, thanks for all the info guys - i'll double double check the original loom but think she'll be ok
    regards
    sam
    T·O·R·O·N·T·O
    Check the wiring where it joins to the connector (at the bulb). It may be on the verge of breaking if flexed a bit.
    Takes about 80 seconds to go to proper brightness/color.
    Wellington,New Zealand
    so the fuse is uprated for the initial current draw?
    Gone but not forgotten
    The original wire is thick enough for higher amperage... and yes, changing the fuse to 15A allows the HID to work.
  1. No fuel supply after swapping harness
    By Snork in forum 5 Series BMW
    Last Post: 10-07-2007, 04:34 PM
  2. HID's glare :,(
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 10-19-2005, 01:16 PM
  3. OEM HID's In E34 With U.S. Projectors
    By Spartiatis in forum 5 Series BMW
    Last Post: 10-17-2005, 07:57 PM
  4. Stabilant 22 supply
    By gordon in forum 5 Series BMW
    Last Post: 09-20-2004, 09:00 AM
  5. M50 Oil Supply Line
    By Steven G in forum 5 Series BMW
    Last Post: 07-24-2004, 08:49 AM
