Results 11 to 20 of 22
Thread: E34's on 18" rims
    El Paso TX
    Hmm I'm 31 now and I don't have a problem with it...
    Maryland
    I have 18s on low profile tires and H&R springs... my car is low and the ride isnt as soft as it was when it was on stock 15s with big tires...
    but the car looks great and the ride is still great... im happy.. and im over 30
    Mar 2004
    Gainesville, FL
    Default hmm
    I am running 18's with 45 series tires to try to absorb some of that impact. Aside from the rear scraping problems that are forcing me to run stock springs in the back with an Eibach setup in the front, the ride is acceptable.
    Corners like its on rails.......with a 4000 pound roller coaster car. lol
    A Young Man with a Plan
    ericbendler@yahoo.com
    Connecticut
    I'm obviously in the minority around here but I'm no fan of the "huge wheel with a black bandaid wrapped around it" look. I'd take the stock alloys over 90% of the wheels I see on this forum although a set of 16" Style 5s would be hard to resist but that would be my limit. The E34 is a classic design, like an older Jag sedan & IMO looks much better with more sidewall then these 17/18" wheels allow.
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Alfa Romeos- 65 Giulia Spider Veloce
    & 66 Duetto 1600 Spider
    Dec 2006
    i'm worried about the weight of 18 inch wheels slowing down and already slow car...but I can't seem to find 17 inch m parallel's
    The only thing I've found (which is VERY important) is to monitor tyre pressures.
    I'm running 40psi and found most of the probs I had before haven't re-occurred. The old 30-all-round doesn't apply to 18s or probably 17s.
    Greg
    E30 318iS & BMW K1200LT
    Charleston, SC
    Quote Originally Posted by alpinaracerX
    I have 18x8.5 with 245/40 tires. And its not that bad.. Its rough sometimes... I'm switching to 17's next season because I'm installing Dinan lowering springs and Koni shocks and I do enjoy the smooth ride.
    I'm running 245/45/18 front and 285/35/18 in the rear
    I would not reccomend going larger then 245/40. The 285/35 rubs in the back and provides a harsher ride then I would prefer.
    Additionally, while 18s look baller on e34s, if I could do it all over again I would go for 17" rims, only because the improved ride and clearance well make up for the extra inch
    '90 535i
    UUC SSK, Bilstein shocks, Eibach spings, EAT chip, CAI, Super Sprint exhaust, Hella euro headlights, HID kit, M5 spoiler
    Dec 2006
    Default Wheels!
    Quote Originally Posted by RiggsyB
    Just how badly is the ride affected?
    I'm running 16" 5 spokes right now (with 225/55R16 tyres) and obviously the ride is exceptionally smooth... I appreciate going to 17's would firm things up a bit and it would lose some of the suppleness, but how bad is it on 18" rims?
    I'm on 275/30/19 rear, 245/35/19 front with no rub or anything. Car is a 95 540i, the ride is good.
    San Francisco. CA
    Quote Originally Posted by GJPinAU
    Greg
    I've been wondering what tire pressures to run with 17"s, but never really thought too hard about it and stuck with the pressures for the standard 15" tires. Should I be running slightly higher pressure front and rear?
    1992 525i 5 speed (Calypso/Parchment) - 1989 525iA (Schwartz/Natur) SOLD
  10. #20
    El Paso TX
    ON a nice day use a spray bottle and lightly spray the tread of the tire, then rol forward and read the damp impression on the concrete like a wear pattern. It'll get you closer than a random add x psi guess will.
    This assumes you have camber within spec.
  1. Major difference between 17" and 18" rims?
    By Jzza4 in forum 5 Series BMW
    Last Post: 04-21-2006, 07:41 AM
  2. 19" Rims on the E34?
    Last Post: 11-03-2004, 03:46 PM
  3. Best tire for 15mm, 7.5" rims, 225 or 235"s?
    By juan525i in forum 5 Series BMW
    Last Post: 10-16-2004, 02:50 PM
  4. do i need spacers for "M" rims from a 95' m3
    Last Post: 03-25-2004, 04:29 PM
