To make this part of the story short.....Shortly after 5500rpm shift, strong coolant smell......Drive slowly for 30 sec, watching engine temp expecting the worst......temp doesn't increase at all.....
Get to stoplight 1 min later, a very small amount of steam is seeping out of the hood, I put the heater on full blast and watch the engine temp more, still not raising at all. I pulled into a parking lot right off of the stop light I was at. Get out of car, trail of liquid following my car into the parking lot.
I pop the hood and see the top radiator hose disconnected!!!
I inspected all belts, and cleaned up coolant that had gotten on mostly the brake booster. I reconnected the coolant hose & re-clamped the clamp. I dumped the half gallon of premixed coolant I had in the trunk into the system, it drank it all with no regrets......
I walked over to the car-x place that happened to be right there, and they gave me a gallon of water, I dumped almost all that in too.
Then drove to a place that would sell me antifreeze without them wanting to charge to put it in themselves.
Filled up with equal amount of 100% coolant to balance out water I put in earlier. Then drove around more stopping 3 times to top off with mixed coolant. Last stop it seemed to have bleed all air out of the system, and was holding the same level in the expansion tank.
Whole time I was doing this I had heater on full blast to make sure coolant was circulating thru that system as well.
So any ideas why my top radiator hose blew off?....I'm guessing it wasn't tightened enough, and blew off. Then the water pump completely dumped all my coolant.
Weirdest thing is, the engine temp never went a hair over it's normal spot, normally it sits just barely over the halfway point.
That's my story for the day![]()
