Results 1 to 5 of 5
Thread: Engine Stumbles
    Aug 2006
    South Florida
    Default Engine Stumbles
    Hi Everyone,
    It looks like owning a 1995 BMW 540i will a learning experience for me. The 540 drives well in every configuration except one. If I floor or step strongly on the gas the 540 stumbles and the check light comes on and goes out. I have driven the car over a hundred miles an hour no problem. I am thinking fuel or spark maybe the problem, any other ideas?
    Len
    change the plugs and fuel filters, what is the code your getting? I can almost bet that you have intake leaks, you will know for sure once it starts getting cold out.
    Cincinnati, Ohio
    If it is stumbling in the lower rpm range i would bet on the coils/coil boots. Chage the plugs and fuel filter unless you know for sure that they are good.
    After the Check engine light flashes can you get any codes?
    So.Calif ( L.A. Beach Area)
    use the search button or my name...there is your answer
    Aug 2006
    South Florida
    Quote Originally Posted by neil_004
    No! there is not a code showing for this. I will have to fix the low beam + and windshield washer fluid low error first (maybe). Low beam + is resident in the info area.
    Len
  1. M20 stumbles
    By Mr. BILL in forum 5 Series BMW
    Last Post: 04-04-2007, 10:34 AM
  2. 1990 325i starts then stumbles off?
    By Stewart E in forum 3 Series BMW
    Last Post: 12-05-2006, 12:37 AM
  3. Stumbles at Idle
    By JMI in forum 5 Series BMW
    Last Post: 10-17-2006, 11:32 PM
  4. m20 stumbles at 2k rpm
    Last Post: 12-28-2004, 02:35 PM
  5. Replies: 1
    Last Post: 09-03-2004, 10:37 AM
