Thread: Low Beam +
    Aug 2006
    South Florida
    Default Low Beam +
    Hello Everyone,
    I am new to this board and to E34's. I recently purchased a 1995, which has the HID lights installed. Low Beam + stays in my dash information area. Is there anyway to remove this, so I can use the system for other information?
    Len
    Jul 2005
    New York
    it's the classic low beam error. if there's a + then low beam isnt the only error being thrown. press the button on the right of the little display to see what else it says. as for removing the low beam error, you have to wire in a relay. do a seach for "low beam error"
    You're my hero.
    USA
    i have another fix for the low beam msg that doesnt require a relay
    2 small 5W incandescent bulbs in parallel with the wiring harness = no more errors
    although there are 2 glowing bulbs when the lights are on, so put them where they wont be a problem.
    Jul 2005
    New York
    ^ can you post pics? that sounds like an awesome fix.
    You're my hero.
    USA
    i can!.......
    once i reinstall the 2nd bulb, there is some wiring in there right now (i have lots of pics of that too) to control the eye rings.
    right now there is a relay with a resistor in it hooked to the low beam harness where the light was to control the rings, so the error light will only come on when i actually turn the low beams on (lkm senses too little current usage?)
    Wellington,New Zealand
    the lkm senses an open circuit,which is strictly correct,so it thinks the bulbs are gone
    Gone but not forgotten
  1. HID Low Beam Failure Fix
    Last Post: 01-14-2007, 02:01 PM
  2. low beam warning...
    By pong in forum 5 Series BMW
    Last Post: 09-12-2005, 02:55 AM
  3. Low beam warning fix
    By rockyfeller in forum 5 Series BMW
    Last Post: 07-21-2005, 12:20 PM
  4. Dip beam failure
    By Jeff in forum 5 Series BMW
    Last Post: 10-16-2004, 10:32 PM
