After numerous days of leaking oil, and an expensive trip to the dealership, I was told that the oil leak was mostly being cause by a leaking valve cover gasket, but could also be a crankcase seal? or oil pan. I replaced the valve cover gasket, changed the oil and filter and the oil leak is now much worse. I've checked and a far as I can see, there is no leak coming from the valve cover seal but it's below that. I've enclosed a few pics which show where the leak is pooling under the car and dripping down, coming from above but I can't find the source. There are a few pipes, coming off the engine that appear to have leaks too at the part they join other pipes. I drives okay, sounds much better since I changed the oil and filter but plumes of smoke come up from under the hood on the passenger side and from under the car where the oil is dripping on the hot pipes when it's idling and an burnt oil smell is strong in the cabin.
As it is, I have no more money to sink into this thing so if anyone in pa or close to erie and is interested in getting the car cheap, I'm open to offers. Otherwise I'm going to garage it until I can afford to get it re-diagnosed.
I appreciate everyone's patience with me since joining the board and everyone's advice, I know I've posted a lot.
Thanks much and as always if anyone has any suggestions or wants to make an offer, just let me know. I can send pics of the car and most of its info and vin is included in my profile.
Thanks again
Nate
