Results 1 to 10 of 12
Thread: Trans. Fluid Change questions, A4S310R....
    Missouri, USA
    Default Trans. Fluid Change questions, A4S310R....
    While doing the radiator/water pump/hoses/EVERYTHING else repair, I noticed that my fluid is a bit on the unpleasant side (what dripped from the cooler lines). SOOOO..it's fluid change time.
    Just a few questions:
    • Fluid Type: Bentley says Dexron II, that is superceded by Dexron III, correct?
    • Screws on the filter TORX?
    • Can fluid be changed COLD? While the car is down awaiting the BIG parts order, this would be a PRIMO time to do the change.
    • 3.2 quarts is accurate? That's the number in Bentley.
    • Small Front Sump. I'm ASSUMING the BMA tranny service kit comes with that gasket so upon reinstallation of the small pan, should I put some fluid in there?
    Thanks a bunch folks.
    I appreciate anyone taking the time to respond.
    I want to do this RIGHT!
    Coastal North Carolina
    Yes, that is correct.
    Yes, T25 or 27, can't remember exact size.
    Sure, no time like the present.
    That should be pretty close. Don't over fill the trans. Start by putting in as much as you can get in without running the engine. Then, when the cooling system is back together, run the engine and finish adding the 3.2 quarts.
    That gasket will come with the kit. No, it isn't necessary to put fluid in that pan, that will only make a mess. The pump will fill that pan up immediately when you start the engine.
    Don't mention it, some of us have been there before!
    Scott
    Wilmington, NC
    01 525iA For Sale
    Coming Soon: 2005 X3 3.0i
    05 Jeep GCL HEMI
    85 318iA SOLD
    96 Jeep GCL SOLD
    Benneton (United Colors of)
    Default i know that you
    rebuilt your unit scott, but i don't remember having torx holding my filter in, and i always try to remember which bolts i have to pull out the torx bit or socket set for...the pelican parts pic looks like mine
    if the car is parked up though, i guess you'd have time to check
    Missouri, USA
    Default Thanks for the input, guys. MUCH appreciated!
    I sincerely appreciate the input.
    Yep, the Jeep has the Torx, the 5er had hex head bolts.
    Scott
    Wilmington, NC
    01 525iA For Sale
    05 Jeep GCL HEMI
    85 318iA SOLD
    96 Jeep GCL SOLD
    Missouri, USA
    Default Hex good, Torx scary....
    Quote Originally Posted by sbcncsu
    Torx scary if some baboon had been inside doing this service before.
    Sure is easy to chew up a Torx if you're not careful.
    Hex is pretty tough for the most part.
    Crossing my fingers it's a Hex.
    My supply of Torx is rather limited.
    Unregistered Guest
    This web page will be very helpful, it did for me when I did my 92 525ia.
    It addresses the A4S310R with lots of pictures and intructions. Good Luck.
    http://www.pelicanparts.com/bmw/tech...Fluid_Auto.htm
    glen-sj
    baton rouge, loserana
    be real careful tightning the 10mm pan bolts, they strip way too easy, if you strip one you can usually use a longer bolt and access some fresh threads, i've even seen some with a real long bolt and a nut on top where it sticks through the case
    Missouri, USA
    Default I hear you....they do look feeble to say the least....
    The torque setting is around 46 in. lbs. isn't it? Whew!
    My 17 month old daughter can generate more torque than that!
    it aint the bolts, the gasket/filter kit comes with new ones with locktight on em, it's the case, it's aluiminum but may as well be tin foil
  1. Replies: 2
    Last Post: 06-22-2008, 09:42 PM
  2. trans fluid change-build your own pump
    Last Post: 12-02-2005, 10:40 AM
  3. auto trans fluid change question for a e36 328i
    By BigKriss in forum 3 Series BMW
    Last Post: 08-09-2005, 09:36 PM
  4. 525i auto trans (A4S310R) fluid leak
    By Alex_525i in forum 5 Series BMW
    Last Post: 04-23-2005, 11:55 AM
  5. belly plate off to change manual trans fluid?
    By scott540 in forum 5 Series BMW
    Last Post: 04-17-2004, 06:41 PM
