it would be cool if it had all of the goodies that go with it, i think you could option that thing up close to 10k
I've seen these in the ETK but never knew any of them made it to the States:
http://cgi.ebay.com/ebaymotors/BMW-X...27663141QQrdZ1
gale
Is there a way to put a totally concealable hitch on a 1990 535i? Something where you can remove the ball when not in use and close up the panel?
1990 535i
117,000mi
Feederick, MD
If it has **** or tires, you are going to have problems.
I don't know how concealed it it, but you can get detachable ones.
Bosal do one, I'm looking to find a supplier at the minute.
I've found a uk supplier:
http://www.bodyshopwarehouse.co.uk/s...&step4=1988-95
£197 for the detachable version, but you still need to make a cut in the bumper![]()
Get a hold of the BMW/Westfalia E34 kit, like I did. Most of the bolt holes are in place on your car anyway. Even the hole for the cables to go through is there.. Just remove the bumper, swap your rams for the solid brackets, bolt the tow frame on (you need to drill 4 holes, 2 each side), bolt the 'in-boot' retaining bracket in place, cut a hole in the bumper for the rectangular trim to clip into, wire everything up, refit the bumper and you're good to go! With practice the horsecock clips into place in <5 seconds. There's a plastic 'pointer' built in the bumper to keep you right.Originally Posted by Airborne001
I've got the E34 fitting instructions/user manual here. I will post it if anyone i interested.
HTH,
Shaun
