95 E34 540IA
I find the drain plug which is a 14mm hex bit plug - I need to get the tool for that..
Where is the fill plug? is it that threaded rod with a funny flat end?
TIA for your advice.
95 M-sport SOLD now NSX
The drain plug is on the passenger side on the vertical side of the tranny towards the front. The fill plug is on the bottom of the pan, in that keyhole in the middle of the rear portion of the pan. It has a riser inside that allows you refill it to proper spec while it is running.
o/______\o
(Oo=00=oO)
