Results 1 to 10 of 12
Thread: were back!!!
    Default were back!!!
    :d :d :d
    Back from what? Shouldn't this post be in the OT section?
    :d :d :d
    back on line... guess the site waited for me to replace my thrust arms today with the Lemforders with M5 bushes.
    Quote Originally Posted by BigKriss
    Jun 2005
    It's amazing how much I miss this place when it is down. Hmmm. How many times did I hit refresh in the last 8 hours?
    May 2006
    NH
    Why'd you chose the M5 bushies over the 750i's?
    1995 540i Manual build 1/95
    cause they is mo better
    Quote Originally Posted by Jehu
    Mar 2004
    NSW, Australia
    Yes, Why?
    May 2006
    NH
    yes, yes why's dey bettah?Would you have used them if you had my 540?I have no complaints with the ride with the new 750 bushys... whats the main difference?
    well working at a bmw shop i get the oportunity to see and use a ton of bushings and over the years i have found out a few things, the blue e34 bushings suck ass, the white 735s are a little better, the green 750s are a little better still but they all are the same crappy design that uses a pop in plastic piece on ether side to support the bushing, the m5 bushing is not solid but is strong enough to support itself with a better internal design, in over 5 years of installing m5 bushings i have not had to replace one, everything else has come back (had some blues comeback in 3 months)
    I took pictures...need to host soon. After 3 sets of FP Groton pencil eraser bushings with plastic inserts that dont fit tight I needed to splurge for the real ****. Dont like the last years shake while braking so I decided to opt for the real bushings that arent handicapped with plastic crap.
    I would at least like a year between replacing these things. The Pass side FP was so stuck it sheared both bolts on the removal tool, good thing I have 200 lbs of bolts to shovel through. took almost 3 hours this time, last was an hour. They were torqued correctly at 68lbs, why it stuck is beyond me, complete bastard to get to pop.
  1. I'm Back.....
    By saj3n in forum 5 Series BMW
    Last Post: 01-19-2009, 08:21 AM
  2. I'm back,,, or am I ?
    By tnt525i in forum 5 Series BMW
    Last Post: 03-12-2008, 11:10 PM
  3. Wow were back!
    Last Post: 06-12-2007, 11:22 PM
  4. I'm back...
    By TheEndIsNear in forum 5 Series BMW
    Last Post: 08-26-2006, 11:42 PM
  5. Another M30 HG down....and back!
    By Mr Project in forum 5 Series BMW
    Last Post: 08-29-2004, 11:37 PM
