Question on fuel pump (Shogun hint hint)
so, the E32 750 has a dual pump system, is there any possibility at all that it could work in my car? i can get a working used one for cheaper than a new pump.
the fuel sending unit is "similar" looking, and i would need a T fitting to get the tubes to hook right, and even the retaining bracket and return o-ring are identical....... i do have a new sending unit for my car sitting doing nothing.
but can it even fit, and if it does, am i asking for a ruptured fuel pressure regulator?
