Thread: ::.. Turbocharger versus Supercharger
    T·O·R·O·N·T·O
    Default ::.. Turbocharger versus Supercharger
    Nice article regarding the title topic. If you're too lazy to read it all, I've chopped out the first and last comments to get you started. So, Jon K, why did you dismantle your super for a turbo again? Just wanna extract all the juice out of the engine eh?
    http://www.pelicanparts.com/BMW/tech...percharger.htm
    A lot of people think that turbocharging and supercharging are the holy grails of power increases. While it’s true you can extract a large amount of power from them, people incorrectly assume that any aftermarket supercharger tossed on a BMW engine will instantly generate heaps of horsepower. As with any good, reliable means of generating horsepower, the addition of a turbocharger or supercharger needs to be carefully coordinated with your engine’s design and your desired performance characteristics...
    <cut>
    ...Which forced-induction unit you install really depends upon your overall goals, which should include ease of installation and budget limitations. If you ask 10 different enthusiasts what their preferences are, you will get 10 completely different answers. There are those who are turbo fans, and there are others who are die-hard supercharger recruits. Obviously, this project can only scratch the surface of what’s involved in designing and implementing a turbocharger or supercharger system.
    Some closing remarks regarding the relative performance of these two systems: If you want a drag car with lots of power off of the line, you should probably go with a supercharger system. It will give you boost at low rpm and a predictable power curve. If you’re looking for top speed on the Autobahn, where you want to squeeze out all the power you can, I recommend a turbocharger system. It will give you maximum power at the higher end of your rpm range. With most supercharger systems, you will achieve maximum boost only when you’re at redline. With a turbocharger, you will have nearly full boost all the way from about 3,000 to –4,000 rpm to redline. If you like to feel the rush of power and want the ability to create gobs of peak horsepower, go with a turbocharger. Turbo systems are also considered to be more flexible in that they can often be designed to fit most owners’ requirements, while superchargers can be a bit more limited. If you want your car to feel somewhat stock with a big push on the high-end, then go with a centrifugal supercharger. If you just want more even power across the entire rpm range, then install a positive-displacement (twin-screw) supercharger.
    In terms of installation ease, the supercharger systems win by a mile. Turbocharger systems can be made to perform better, but they generally require more time, money, and installation effort to achieve this end.
    PA
    Well my supercharger decided it would taste a silicone vacuum line and destroy the compressor wheel. So then it was either rebuild the supercharger, which was fine, or spend similar money and make 200 more horsepower.
    Guess which I chose?
    If they say that supercharging is better for Drag, then why are the top drag BMWs all running huge turbos? The turbos generate more power more efficently for them to run, since it doesn't really matter at what rpm the boost builds for a drag car, they can have as much lag as they want. They can do that with the fact that they're in the high rpms the entire time.
    PA
    Kevin - they are talking about roots or twinscrew superchargers. CF blowers suck off the line - its basically a belt driven turbo with less torque and less power. I agree, all fast 1/4 bmws are turbo - especially because you can anti-lag a start and have boost off the line. A blower won't do that.
    Jul 2005
    New York
    like that andreas guy over in sweden. 9.42 @ 155mph on pump fuel. holy ****. (he's got a turboed s38 in an e30, no?)
    You're my hero.
    PA
    Turbo S38B38 in E30 M3 but its a very worked motor, 8:1 cr pyramid rings cut in the block, etc.
  1. Replies: 0
    Last Post: 11-25-2008, 01:16 AM
  2. 525TDS versus 535?
    By Barney Paull-Edwards in forum 5 Series BMW
    Last Post: 03-23-2007, 03:26 AM
  3. .002 cents versus .002 dollars....
    Last Post: 12-12-2006, 06:06 AM
  4. Replies: 6
    Last Post: 02-13-2006, 01:06 PM
  5. Ex girlfriend versus m3, post off of
    Last Post: 11-03-2005, 07:37 PM
