Results 1 to 5 of 5
Thread: Newbie needs help on M60 oil leak, upper oil pan?
    Sep 2006
    San Jose, CA
    Default Newbie needs help on M60 oil leak, upper oil pan?
    Hello,
    I just picked up a very very clean 94' 530i with 98k on it last Friday. I read this forum for things to look for before I bought it. I just love E34 classic body. The car drives great shifting very smooth. Still ... I just happened to know yesterday that the car has some serious oil leak issue. I'm sure why I didn't detect the oil leak when I inspected the car - the guy drove ~30miles to show me the car and I didn't see any oil leak. Today if I drive ~10miles, there will be at least 3 drops of oil. It is dropping at the bell-housing (not sure if this is how you guys call it) right onto a sway bar before hitting the ground. It seems to be coming down from the driver side (US.)
    I took it to a well-known real BMW indy (my friend recommended) in north San Jose area. He mentioned there are 2 possibilities.
    1.) Upper oil pan - need to remove suspension? ($500 charge for parts+labor). He will also do the lower oil pan re-seal.
    2.) Rear main seal - need to drop trans ($700 charge for parts+ labor).
    Questions:
    I did a lot search through this forum but I've never seen anyone with M60 engine mentioning about "upper oil pan" problem. Do you guy use a different term for it? I told the indy about other possibilities that I found from this forum (valve cover gasket, timing chain cover gasket, ...) He said this should not be the problem. Should I go for an upper oil pan fix and pay $500 for this? He cannot gaurantee if this will fix my problem though. If not, next is $700 rear main seal ...
    Another problem, I have 1221 C/E code from stomp test. The indy mentioned it should not be the in-take leak because the car idles very very smooth. He will charge me $70 (labor only) for replacing the two O2 sensors. I told him that I will do it myself. Where is your good on-line BMW parts store?
    Your help is greatly appreciate!
    94' AlpineWhite 530i, 5 spd Auto, 112K miles, Mfg in 4/93
    Sep 2006
    Potsdam, NY
    www.bavauto.com will have most of your parts.
    Sep 2006
    San Jose, CA
    Default picture of the leak
    Quote Originally Posted by horseheadnebula
    Thanks, hourseheadnebula for the link.
    Here is the picture of the leak.
    Name:  m60 oil leak.JPG
    If anyone has any comment, please let me know. I told my indy I may do the upper oil pan this Friday.
    I'm sure he knows but remind the indy about the oil pump bolts while he's in there.
  1. Follow-up on my M50 oil leak & coolant leak
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 03-06-2008, 10:51 AM
  2. Newcomer - Newbie Section - Newbie Owner
    By rufryder in forum 5 Series BMW
    Last Post: 09-27-2006, 01:16 AM
  3. upper radiator hose on M60
    By brosher in forum 5 Series BMW
    Last Post: 08-07-2006, 10:23 AM
  4. Upper Strut Mount
    By IN10CT in forum 5 Series BMW
    Last Post: 06-11-2006, 01:40 PM
  5. Newbie with some newbie questions re: wheels, CD changer
    By hauler_525iT in forum 5 Series BMW
    Last Post: 10-18-2005, 10:49 PM
