Results 1 to 10 of 13
Thread: Broken gas door?
    Connecticut, USA
    Default Broken gas door?
    Well, got out of my car to fuel up after leaving class one day, and when I got around to the back I realized that my gas door was hanging all crooked. At first glance I definitely thought somebody smacked/pulled the **** out of it, but it appears the plastic just cracked.
    Has this happened to anyone else? Should I replace the whole plastic piece, or you guys think some Gorilla glue will do the trick?
    - Jeremy
    P.S. Also still the possibility somebody could have been trying to siphon a few gallons
    1990 Islandgrun 535iM Sedan
    3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
    May 2006
    NH
    I hear they go often. Mine stayed open for a few days after i got it. Now it won't stay open. Its not a major inconvenience so i haven't replaced it.I read it is as would be expected, a cheap , easy fix to replace the door.
    1995 540i Manual build 1/95
    Jun 2005
    The fuel door hinge died on my husband's 90 525 that had 200,000 miles when we sold it. Thought I had a link for the part for you but must have deleted it. It seems like it was less than $20 bucks. Not having that door close flush always looked tacky in my opinion.
    Connecticut, USA
    Quote Originally Posted by Gayle
    Yeah, it's really bothering me
    BTW, are you just running an eisenmann muffler with otherwise stock exhaust? I was using your exhaust thread for research but I can't find it anymore...
    Jun 2005
    Quote Originally Posted by ILoveMPower
    Yes. It has a very growly sound. I replaced the resonator at the same time and the resonator is so effective you can hardly hear the exhaust in the passanger compartment. I love how the car sounds when the valet parkers drive it off and my husband loves how it sounds when I pull in the garage. But driving the car, the only time I hear the exhuast is when I am decelerating.
    I picked the eisenmann on the 3 bears theory. I thought the supersprint would be too quiet and the tri flow would be too loud and the eisenmann would be just right. It turned out to be a little quieter than I thought, but I think if I had not replaced the resonator it would be perfect for my taste.
    Solicting input on the exhaust
    Installation
    Do NOT use Gorilla glue, epoxy, or any adhesive for that matter. Just replace the hinge. Its inexpensive and usually available for immediate purchase at the dealer. The PO of my car used glue to put attach the door to the hinge. Not only was it crooked, but it took the body shop some effort to clean all the glue off during the repainting. New hinge was about 15 bucks and 10 minutes of installation labor on my behalf.
    Connecticut, USA
    Quote Originally Posted by Rus
    Thanks, this was EXACTLY what I wanted to hear
    Anyone know how many clips there are for each door panel? (might as well scoop them up while I'm at the stealer)
    Jul 2005
    New York
    check realoem.com. I'm not in any state of mind to figure out how to do screen shots to paste. It's pretty straight forward to get the clips. I have to get new clips for mine as well, as the body shop that fixed my car after my accident conviently forgot to add the clips. it shouldn't be hard.
    You're my hero.
    Albuquerque, NM
    I have a limited supply of brand new OEM fuel filler door hinges:
    $10 ea. + $3 postage, PayPal happily accepted:
    http://www.nmia.com/~dgnrg/for_sale.htm
    gale
    Connecticut, USA
    Quote Originally Posted by gale
    lol, awesome.
    $$$$ sent.
  1. broken door bracket repair E32 - DIY
    Last Post: 12-11-2024, 11:47 PM
  2. broken door bracket repair - DIY
    Last Post: 02-04-2023, 05:50 AM
  3. Help: Outer door handle broken
    By bimmerred535i in forum 5 Series BMW
    Last Post: 07-10-2009, 08:43 PM
  4. door lock repair - broken spring
    Last Post: 04-25-2009, 10:27 PM
  5. Round #283: Name that (broken) door part!
    By swenpro in forum 5 Series BMW
    Last Post: 11-03-2008, 04:10 PM
