Results 1 to 8 of 8
Thread: 80 Amp Alternator?
    Honolulu
    Default 80 Amp Alternator?
    My touring has a case of dimming or flickering headlights.
    So I swapped out the LKM with a re soildered spare, and still the same thing...
    So I suspect the regulator, battery terminal grounds etc.
    Pull the seat and the terminals are perfect and coated with terminal sealer.
    Check the alternator..and It's a wimpy Bosch 80A, Huh?
    I leaf through the PO's repair records and no alternator...
    My specs show a 140 Amp alternator is supposed to be in this model.
    baton rouge, loserana
    probably a used unit from a 325
    Honolulu
    Default Looks like a Reman Bosch
    Funky sticker over the Bosch info amd no BMW logo.
    Cheap bastage repair.
    probably cost him $600.00 plus lol. It may be only 80 amps but has worked, maybe the brushes are worn ir the regulater?
    Quote Originally Posted by Blitzkrieg Bob
    Honolulu
    Default Just gonna replace it
    I can find the right one for @ $200
    I would check first the charging voltage. Maybe just the regulator is defective.
    Even E32 735 were partly (as standard) delivered with 80 A alternators, depending on what was installed as additional gimmicks.
    Then came 115 and only the 750 has a 140 A alternator.
    Even Autohaus is offering 80 A
    http://www.autohausaz.com/search/pro...412@Alternator
    Melbourne, Australia
    Did you check the engine ground ie. cable from engine to body making good contact?
    Bill G Melbourne Australia
  1. Alternator.
    By bloodyvsunday in forum 5 Series BMW
    Last Post: 03-22-2009, 05:31 PM
  2. E34 Alternator
    By Danog22 in forum 5 Series BMW
    Last Post: 06-15-2006, 03:48 AM
  3. alternator ??
    By Dr. evil in forum 5 Series BMW
    Last Post: 01-26-2006, 08:43 PM
  4. Alternator?
    By howdydee2003 in forum 5 Series BMW
    Last Post: 11-22-2005, 07:38 PM
  5. Anything else I should do while the alternator is out:
    By Beachcomber in forum 5 Series BMW
    Last Post: 05-05-2004, 11:19 AM
