Results 1 to 2 of 2
Thread: 525 i 1995 automatic
    Default 525 i 1995 automatic
    Hello Everibody,i Nedd Help With The Following: How To Replace The Plastic Bezel That Indicate The Shifter Position And How To Remove The Shifter Knob And The Plastic Frame Underneath .
    Marino
    baton rouge, loserana
    knob 2.5mm allen on front side, console panel lift front with pick/hook tool and pull forward after you get the front about as high as you can lift it, most of the plastic around the prnd321 is glued together and easyly destroyed, pretty much the only replacable part is the tank tread looking piece that covers the slot, it's a few bucks at the dealer, it slides out of it's channel with a little work but be careful the round bits that it rolls up in are brittle and when broken beyond glueing the whole piece is trash
  1. 1995 bmw 525 i automatic
    By marinos90209 in forum 5 Series BMW
    Last Post: 08-01-2006, 09:53 AM
  2. S38 automatic ?
    By X-ray in forum 5 Series BMW
    Last Post: 10-13-2005, 06:12 PM
  3. bmw automatic
    By bull1117 in forum 5 Series BMW
    Last Post: 09-21-2004, 10:19 PM
