Thanks for the info! What are the best tire size to go with these rims?Originally Posted by liquidtiger720
Offset is fine. Tires won't fit. You'll need new ones.
www.KaRealtySF.com
95 540iA: Euro Clears & More Mods to Come Soon!
Sacramento, CA USA
If your car is lowered, then the offset will most likely cause the tyres to rub the guards. I know, because I have M Parallel wheels on my lowered E34 with a 13mm offset all round, and they rub, badly.
If you use the rear wheels with a 25 mm offset, then the wheel will come very very close to the trailing arm, nut i'm not sure if it will rub or not.
If your car is not lowered, you may be OK
John
Pics of my E34 M5 -> http://www.jrobbo.com/M5
http://www.miata.net/garage/tirecalc.htmlOriginally Posted by Thayne
The car is not lower so hopefully I will be ok!Originally Posted by jrobbo
Sacramento, CA USA
Thanks!Originally Posted by wjbell
Sacramento, CA USA
