BTW she has fluid and its still red but there is a hint of darkness...
Help... I pulled out of my parking lot at work today and the BMW started slipping during its shift from 1st to 2nd. Then when I tryed to take off from the stop light, 1st gear shuttered really bad and acted like it was going to slip out. She then had plunty of power to the wheels untill it went to hit 2nd the it slipps for a few seconds and engages second. From second on she is just fine and reverse is normal. This is my daily driver 525i automatic... Please help... Thanks guys...
Josh
1990 BMW 525iA
2000 Toyota Corolla CE
2007 Toyota Echo
Josh
1990 BMW 525iA
2007 Toyota Echo
STOP DRIVING IT!
when the trans slips all its doing is frying the clutch packs ruining it. could be low on fluid or the filter could be clogged. could be many things but that is the starting point, sounds like low pressure.
Yeah, I limpped it home, only a couple of miles, and I'm burrowing my neighbors 240sx... This weekend I'm dropping the tranny pan and changing the filter and fluid... I was warned to just change the fluid and not to flush it... Any recomendations on fluids, weve discused this before but I want to use what will be best for a trans on the edge. BTW the tranny fluid is still red and doesnt look to bad just a little burnt looking. No metallic luster like ive seen in some cars right after the trans goes pop...
Josh
1990 BMW 525iA
2007 Toyota Echo
I heard of the same problem on a 89' 535i and it turned out to be an ECU problem.
Dextron III, filter, gasket and pray to Our Mother of Holy Hydromatics for deliverance from a rebuild.
Forget rebuild... If she's dead I'll part her out and buy a 535I with a 5 speed like I should of in the first place...
Josh
1990 BMW 525iA
2007 Toyota Echo
i have excact same problem here.... slipping from 1 to 2 gear.
changed the oil and filter yesterday... problem still there... maybe i should reset the ECU... But would it be enough just to reset the primary ECU or du i have to take the plug from the auto tranny main unit
I dont understand how the ECU could cause a mechanical slip... Is this actually a possibility...
Josh
1990 BMW 525iA
2007 Toyota Echo
the ATC would control the operation of the solinoids at the shift points.
sliping sounds more mechanical/hydrolic
