Results 1 to 7 of 7
Thread: what did i break on the 535i?
    Charleston, SC
    Default what did i break on the 535i?
    I have a 535 running Bilstein shocks with Eibach spings, and recently I have been bottoming out like in the rear. I didnt think much of it until this afternoon when I went out for some spirited driving. When taking corners the ass will slide like **** and it makes a clanking sound similar to bottoming out. What do yall think I broke?
    '90 535i
    UUC SSK, Bilstein shocks, Eibach spings, EAT chip, CAI, Super Sprint exhaust, Hella euro headlights, HID kit, M5 spoiler
    T·O·R·O·N·T·O
    Have you at least looked or otherwise just did a push down on the corners?
    Default I had a Bilstein seize up on me.
    It seized in the extended position & made the ride very uncomfortable. It was horrible, & I knew what had happened within a mile or so of driving briskly on crappy, but fun, backroads with the entire family in the car.
    I've since replaced the front Bilsteins with Sachs struts for a much better ride.
    erased due to slander
    Maryland, Virginia, D.C.
    The bilsteins have a problem with bleeding fluid out of them, making them pretty useless. Check the shocks/struts. I've found the sachs and kyb's to be fairly reliable. The ride of the sachs are very nice as well.
    Quote Originally Posted by ThoreauHD
    Most likley the upper mounts have failed. Many are not very strong or perhaps the washers are incorrectly installed- this will cause a prompt failiure of the mount. If the mounts were not replaced, the new shocks would likely send the old ones to their grave much faster. Check them by removing the rear seat cushions and looking under the rubber caps. Nick
    Charleston, SC
    Quote Originally Posted by genphreak
    Good call! I remember I busted a RSM back when I had the 328is, and the symptoms were similar. I'll give it a check tomorrow and report back
    '90 535i
    USA
    probably the mounts, but maybe subframe mount failure?
  1. OT:gimme a BREAK!
    Last Post: 02-07-2007, 01:13 PM
  2. How do I break into my car?
    By ronnie in forum 5 Series BMW
    Last Post: 08-16-2004, 06:55 AM
  3. Break Light Circut Message... But Break Lights Work
    By T. Martin in forum 5 Series BMW
    Last Post: 08-02-2004, 07:07 PM
  4. Ok...what did I break now?...
    By mancini_mark in forum 5 Series BMW
    Last Post: 02-26-2004, 02:47 PM
