Results 1 to 3 of 3
Thread: Ground check
    Mar 2004
    So Cal
    Default Ground check
    Where would I need to check for ground while having a problem with an instrument cluster? Would it be at the connectors or is this an engine bay type ground? I had an earlier thread for the instrument cluster, but I didn't get an answer for the ground problem. In case you didn't remember, it was a garbled message problem on the lcd. Thanks.
    Greg Mendoza
    Ground distribution you can find here
    http://www.e38.org/e34/e34_92_etm.pdf
    I am not sure for the E34, but on the E32 there are 3 (?) under the steering wheel area for that.
    Mar 2004
    So Cal
    Thanks, Shogun. I'll pull out the Bentley manual and confirm.
    Greg Mendoza
  1. is this the ground?
    Last Post: 04-01-2009, 02:36 PM
  2. Ground distribution
    By Claude in forum 5 Series BMW
    Last Post: 11-09-2008, 08:10 PM
  3. Ground controls
    By weazman187 in forum 5 Series BMW
    Last Post: 01-09-2007, 11:44 PM
  4. Short to Ground
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 12-23-2006, 01:15 PM
  5. coolant on the ground
    Last Post: 09-13-2006, 01:46 PM
