Originally Posted by
JMI
The Car: 1989 535i Auto 125,000 miles
The symptoms: Happens only at idle (about 700 rpm). The engine will start to stall, rpm dropping off, and then will surge momentarily to about 1100 rpm and then settle back to 700 rpm. Sometimes it will completely stall. I can usually prevent this surge/stall by slightly stepping on the accelerator.
There appears to be no regular pattern when this happens except maybe when slowing quickly.
Stomp test gives 1444 - no code.
Can't find any vacuum leaks, but have not ruled that out altogether.
Have cleaned ICV throughly. It buzzes when engine runs. Resistance is in range -approximately 40/20/20.
Throttle Position Switch checks out OK.
Tempted to change out ICV but don't want to spend $145 bucks for nothing.
