Originally Posted by
alex520
my problem with my window is that the white plastic bits keep coming out of the ridge their supposed to sit on. this has resulted in my window coming down but not straight - comes down so far then starts to come away from the edge of the door (if you know what i mean?) can get it back up again but only if i use my hand to force the window back into place when im putting it up. any ideas on how to fix this.
You talking about the plastic pieces that slide on the tracks at the bottom of the window? You can buy new ones for a few bucks at the stealer.
The other plastic piece which I read about giving people fits was the little plastic /teflon washer that rides along the horizontal anchored track. If this washer breaks, the regulator arm will not seat tight on the track and the window will wobble as it goes up and down. There are posts on the forum and roadfly that describe this problem better than I just did. The short of it is that you can't buy that piece and need to buy a new/used regulator to get it fixed.
'94 540I 6spd/205000 miles
