Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Brake Ware Sensors
    May 2006
    NH
    The guy i bought it from put new pads on in April . I've put about 6,000 miles on it . If they're worn enough to replace already i guess my rotors are hooped.
    1995 540i Manual build 1/95
    Albuquerque, NM
    There are only 2 sensors, 1 on the inside pad of the left-front, and the other on the inside pad of the right-rear, so they're only accurate if all pads are wearing evenly, as already mentioned. The nice thing about e32/e34 brakes is the outer edges of the pads are recessed slightly and don't go clear out to the o.d. of the rotors. You'll notice there is a slight ridge on the outer brim of used rotors, and if they do end up going metal on metal, it's the pad's metal backing rubbing on the ridge, and not the braking surface itself. You do have a grace period when you hear the squeal, before damage is done. I would tend to it within a few hundred miles if that's the case.
    gale
    May 2006
    NH
    Like i said the squeal didn't really sound like other clips style brake wear sensors I've heard and disappeared after a minute. I thought there might be like an audible electric things that goes off or something . I'll check the pads tomorrow but they've only got 6,000 miles on 'em . If they're already bad I'd be disgruntled..
  1. Replies: 0
    Last Post: 12-02-2006, 10:39 AM
  2. Replies: 6
    Last Post: 10-22-2006, 08:51 AM
  3. Replies: 0
    Last Post: 05-31-2004, 06:14 AM
  4. Those pesky brake sensors are buggers!!
    By Am Piobaire in forum 5 Series BMW
    Last Post: 04-28-2004, 07:35 AM
  5. Replies: 3
    Last Post: 03-11-2004, 03:02 PM
