Results 1 to 10 of 18
Thread: fixed head now what?
    dublin, ca
    Default fixed head now what?
    Hey,
    As some of you know I bent all of my exhaust valves. They all crashed into the pistons because of a missshift. Anyways i got the head squaird away with all new exhaust valves reground intakes and seats on all of the valves. I had them put a some shims on all of the valve springs to bring up the spring tention a little bit. Im doing a head gasket kit and putting arp head studs in. Im also repplaceing the thermostat and oil and coolant. Does anyone have anything elts i should repplace while im there?
    Houston, Tx
    When you said crashed into the pistons... do you mean they literally hit them and left marks in them? If they left chunks or imprints, you better just go ahead and change those too otherwise you're inviting that area to become a hot-spot and break apart.
    East Brunswick, New Jersey
    I don't agree with the logic. The piston may have been damaged due to mechnical impact. The dented area won't get any hotter than undented part.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    unless there are sharp edges.
    Quote Originally Posted by yaofeng
    kingsbridge, devon, uk
    better safe than sorry, you'll rue it if you don't do it now while its all in bits
    Houston, Tx
    Its pretty simple, thinner metal, weakest link to combustion heat and compression. If I still have the pictures, I'll be glad to show you what a 401 V-8 looks like after such a thing happens
    Orlando, FL (Gainesville)
    did your valves make any artistic shapes like my buddy's?
    Houston, Tx
    THAT is freakin art! o_O
    dublin, ca
    They did scrach the pistons and took a little ding off of one but i sanded them down flat and smoothed em out so there shouln't be a problem.
    Default Um....you sanded them?
    with what? how much did you take off? are you sure of the integrity of the piston? you have less material now so there is going to be more heat. Your compression ratio will change as a result, and each cylinder is not going to be as equal as possible as intended by original manufacturing. What exactly do you mean by "ding"
    Why are you using arp head studs? Is there something wrong with the stock hardware?
    Quote Originally Posted by pyro
  1. milled head + euro motor = thicker head gasket?
    By 31Hertz in forum 5 Series BMW
    Last Post: 07-30-2007, 05:50 PM
  2. cylinder head corrosion - can it be fixed properly?
    By Randell in forum 5 Series BMW
    Last Post: 06-07-2006, 03:37 PM
  3. 525i Head Gasket/Head problems...
    By Spud in forum 5 Series BMW
    Last Post: 08-11-2005, 01:16 PM
  4. Control Check fixed/not fixed??
    By Ian Dodd in forum 5 Series BMW
    Last Post: 03-29-2005, 04:33 PM
  5. Blown Head gasket / Cracked head M50 Vanos
    By MotoMan in forum 5 Series BMW
    Last Post: 03-09-2005, 12:46 AM
