Results 1 to 4 of 4
Thread: Spittin', Sputterin' 535i
    Aug 2006
    East Tennessee
    Default Spittin', Sputterin' 535i
    1986 535i e28...When I first crank the car in the mornings from sitting overnight, the car cranks, idles and runs fine. BUT as the engine heats up and I leave for work, I lose acceleration, and the car starts to sputter and spit really bad. When I coast down hill with my foot off the accelerator (but clutch still engaged) the car tends to backfire a bit, or sputter even worse. When I come to a stop and the car is idling, it sounds like a Harley or something as the car revs while it is at idle...not much, but enough to notice. Could this be an oxygen sensor giving me trouble?
    Huuhh, E28, maybe you ask her
    http://www.bimmerboard.com/forums/e28/
    BUT: what have you done/changed such as distributor, rotor and so on?
    Tested the temperature sensors?
    Aug 2006
    East Tennessee
    I have recently changed plugs (Bosch) and replaced the TPS, thinking that it may be that, but it did not remedy the problem. Where can I find the procedure for testing the temp sensors?
    it is probaly in the Bentley Repair Manual for the E34 or even the E32. Do not know if there are details on E28.
  1. 535i auto LSD into my 535i manual non LSD?
    By Waynegro in forum 5 Series BMW
    Last Post: 06-21-2006, 07:31 PM
