Using the excellent info from Robert, I was able to stop my leak. I did a simpler but a less thorough job than Robert's instructions. Never the less, the leak was stopped.
I just tightened the 2 bolts holding the crank position sensor bracket. Top one was easy to get to after removing air filter housing. I got to the bottom one with an open end wrench positioned over the top of the AC compressor without removing it.
Here are a couple of pics
Remember to gap the crank position sensor properly after tightening. I found tightening the bolts on the brackets changed the gap. Since the gap is only 1mm, changing the gap can cause actual contact between the sensor and the teeths on the harmonic balancer.
The leaked oil would accumulate just below the bottom bracket bolt (lowest point). Looks like it would drip onto the AC compression brackets and eventually work toward the lowest point on that.
I also had leaks in the oil pan gasket. The bolts were awfully lose (dealer replaced the gasket 2 years ago). Not sure why they would have loosened? I just tightened the bolts a bit and the leak stoped here as well.
