Results 1 to 10 of 11
Thread: subframe doom in NC!!!
    Aug 2006
    Raleigh, NC
    Default subframe doom in NC!!!
    Hey guys
    I'm new to this forum, but need some assistance.
    I have impending rear subframe failure (E36) and need to find a qualified (and willing) shop in the Raleigh-Durham area.
    If anyone knows of an independent that has done this repair before, please pass the info along.
    Thanks!
    1992 325is
    JC Chip
    K&N and CAI in bumper
    Bilstein Sports & progressive springs
    18 x 8.5's w/ 225 40's
    Vented discs & sport pads
    Short Shifter
    Hardwired V1 (Pays for itself!!!)
    Aug 2004
    RTP North Carolina
    Default You can try Shade Tree Garage
    http://www.stgbmwservice.com/
    Email them and ask
    NC
    Default Scott, he's already tried them...12 hour estimate and would be the guinea pig.
    Quote Originally Posted by smcgowan
    scotsman is a coworker of mine, and this is primary transportation, so it needs to be done right but efficiently!
    Bill B.
    95 525i
    Apex, NC
    I'm not sure about what exactly the repair is you need, but I've always had good luck with Renaissance Auto (Cary) 919-461-0700. Not as cheap as I'd like, but always did good work for me.
    http://www.renaissanceautocare.com/
    Scott
    '11 TSX Sport Wagon
    '00 328i
    '78 MGB
    '08 Saab Aero
    Aug 2006
    Raleigh, NC
    Thanks- I'll give them a try.
    The problem is that on early (non-M) E36's the center suspension member (diff carrier) can acutally rip out the mounts to the chassis. The risk increases with high miles, hard driving, and aftermarket suspension / wheels. I'm 3 for 3...
    Apparently replacing all the rubber bits early on is the best defense, next to installing the BMW reinforcing kit (standard on M and later E36's).
    1992 325is
    JC Chip
    Short Shifter
    Elm Grove Farm, NC
    I've got a welder!!
    Bring it on and we'll git-r-done......
    Just need someone to help and it shouldn't be too hard, anyone got any documentation on what EXACTLY needs to be done?? I've heard alot about this failure, but never actually seen one in person. You planning on using the "kit" to fix it or ??
    Bret.
    ps- I'm serious.
    Elm Grove Farm, NC
    OK, I've done my research.
    Looks like the repair parts (BMW) are readily available for ~$100 or so. The main labor expense is removing/reinstalling the subframe/diff/etc. Some folks have done the R+R themselves, and then found a mobile welder to do the welding of the reinforcement plates. It should not be a difficult job for a welder with basic skills and a good MiG or TiG welder to do the repair.
    I'll be glad to help, if one or two of you local guys are willing to help with the subframe/diff R+R.
    HTH.
    Bret.
    Apex, NC
    Need to check my '93 318 then I guess?
    Bret, did you ever get an E36 coupe donor?
    Scott
    '11 TSX Sport Wagon
    '00 328i
    '78 MGB
    '08 Saab Aero
    Elm Grove Farm, NC
    Quote Originally Posted by ScottyWM
    Scott,
    couldn't hurt to check your 318i, but I doubt it has enough HP to put too much strain on those mounts....
    I don't have any E36 coupes, but I've acquired 2 E36 sedans since you were last out here, plus that E36 318i cabrio.
    Thanks, Bret
    Aug 2006
    Raleigh, NC
    Bret
    I appreciate your enthusiasm, and I hope you're not looking to add another E36 to the lot!
    Truett got back to me and Shadetree is willing to do it, but not until September sometime. I don't think that the car will survive that long:
    I was under the car tonight doing some additional inspection, and the pass side front mount is at least 1/4 torn out already. The threaded stud spins free of the sheetmetal, too. Ouch!
    Looking online I found all the rubber mounts and rei kit for about $160. I'm going to call the dealer to see if they can do better with CCA discount.
    I figure with an arbor press, a welder and some luck it is doable. I've never turned down a challenge before, and this one seems like a real peach.
    So, if we're looking for a long day (or days) of work- then I'm game.
    1992 325is
    JC Chip
    Short Shifter
  1. Check out the Spike of Doom
    Last Post: 07-16-2008, 10:36 PM
  2. Tinkling noise of doom
    Last Post: 06-22-2008, 06:54 PM
  3. E34 V8 Front Subframe
    By johnwilson in forum 5 Series BMW
    Last Post: 11-11-2007, 02:50 PM
  4. Cut into the subframe - advice?
    Last Post: 05-31-2007, 04:15 PM
  5. Impending Doom??
    By John B. in forum 5 Series BMW
    Last Post: 11-09-2006, 04:40 AM
